February 11, 2014, 15:03 |
Mesh check fail after scaling
Kora
Rep Power: 14 |
Hi everyone. I'm working on a case which consist of a bigger free stream domain and a smaller rotating domain consisting a turbine. I checked the mesh after I imported the two meshes and set up the interfaces and it was fine. However, when I checked the mesh again after scaling, I had a warning about "invalid or face with too small area exists" and mesh check failed.
Is it possible to find out where these small faces area so that I could fix it? Are there any other possible ways to go about it apart from changing the mesh? Thank you in advance. |
[ICEM] Orthogonality/Skew issues in 3D unstructured mesh | eddyy19g | ANSYS Meshing & Geometry | 3 | February 13, 2014 09:36 |
Mesh check failed | subhas.hunasikatti@gmail. | FLUENT | 0 | January 19, 2014 04:09 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 13:43 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 07:21 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
