Mesh check fail after scaling
Prev Previous Post   Next Post Next
Old   February 11, 2014, 15:03
Default Mesh check fail after scaling
Kora
Aoki is on a distinguished road
Hi everyone. I'm working on a case which consist of a bigger free stream domain and a smaller rotating domain consisting a turbine. I checked the mesh after I imported the two meshes and set up the interfaces and it was fine. However, when I checked the mesh again after scaling, I had a warning about "invalid or face with too small area exists" and mesh check failed.
Is it possible to find out where these small faces area so that I could fix it? Are there any other possible ways to go about it apart from changing the mesh?
Thank you in advance.
Aoki is offline   Reply With Quote
[ICEM] Orthogonality/Skew issues in 3D unstructured mesh eddyy19g ANSYS Meshing & Geometry 3 February 13, 2014 09:36
Mesh check failed subhas.hunasikatti@gmail. FLUENT 0 January 19, 2014 04:09
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 07:21
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
