Velocity Inlet/Outlet - Sinusoidal velocity
Old   February 16, 2014, 08:54
Default Velocity Inlet/Outlet - Sinusoidal velocity
Jul
Jul1731 is on a distinguished road
Hi everybody,
I am working on the active control of boundary layer and trying to modelize a pulse jet localized on the suction side as shown on this picture:
I tried to set a sinusoidal velocity to get a blowing/sucking system however as soon as the velocity goes under zero, the calculation diverges and in addition, the velocity resulting is not negative but extremly high (3000 m/s instead of -150 m/s )
So my question is: is it possible to set a negative velocity to modelize suction ? and if yes, how should i do ?
Note that I want to modelize blowing and sucking, so I don't want to set a pressure outlet to only get a suction surface.
Thank you,
Cheers,
Julien
Jul1731 is offline   Reply With Quote
LES and TKE calculations MST Main CFD Forum 3 May 30, 2016 06:26
Having trouble adapting serial UDF to work in parallel muyuntao Fluent UDF and Scheme Programming 1 November 10, 2015 13:42
Radial velocity and tangential velocity on centrifugal fan, johnnyp FLUENT 2 May 24, 2013 07:10
Transient sinusoidal velocity inlet mrestrepo30 FLUENT 2 September 27, 2010 12:03
how to compute relative velocity from absolute? spk Main CFD Forum 3 July 9, 2010 08:42
