viscosity, dpm particle matter
Old   January 14, 2021, 03:00
Default viscosity, dpm particle matter
kim jihyun
mooving is on a distinguished road
hello,
i have a problem related on viscosity.
in fluid setting, there are equations about viscosity which have one parameter(temperature).
but I'm using dpm model and it seems like particles don't affect fluid viscosity
because the viscosity is the function of temperature.
then i think, at least, it has to affect the flow of fluid.
but it also seems like particles don't affect the flow or flow velocity either.
how can i make particles affect the flow of fluid?
mooving is offline   Reply With Quote
Old   January 14, 2021, 07:31
pakk will become famous soon enough
Select the button "interact with continous phase" in the discrete phase model option screen.
pakk is offline   Reply With Quote
Old   January 14, 2021, 12:38
kim jihyun
thank you for the answer
I checked that, but it still doesn't seem to work...
Old   January 15, 2021, 00:52
Default i solved the problem
kim jihyun
i selected the discrete phase domain from none to phase2
and the viscosity of mixture changed successfully.
but what does discrete phase domain mean?
DPM: Table of Distance Traveled of each Particle JacobMillerChemE Fluent Multiphase 0 July 17, 2020 13:56
DPM particle time step amos FLUENT 1 January 4, 2020 08:46
UDF for DPM particle deposition modelingpa haghshenasfard Fluent UDF and Scheme Programming 10 September 15, 2019 02:03
DPM particle traCKING sajeesh FLUENT 1 April 27, 2013 23:12
Burning Particle (DPM) sega FLUENT 2 July 31, 2010 04:08
