Aerodynamic analysis of bullet
Old   February 19, 2014, 03:58
Default Aerodynamic analysis of bullet
Hernus
Hernus is on a distinguished road
Hallo,
I'm currently investigating in the Aerodynamics of a flying bullet. I'm quite comfortable with the set-up I use.
The bullet analysis is for speeds up to 3 Mach, attack angles up to 6 degrees, and a rotational bullet (wall) of up to 22 000 rad/s.
The results I get is almost acceptable, except the force in z direction and moment around y-axis on the centre point of bullet (Magnus force and Magnus moment). These values jump around a lot and never converged to the same value even if the same conditions is run again.
I have a feeling this is about the mesh, I'm currently just using the meshing system inside ANSYS with just the default inflation from the body towards a greater outfield. I tried to refine the mesh around the bullet and inflate more and more gradually with extensive bodies but with no luck. when I ran the simulation in Fluent I get an "Floating point f" error. I really tried a lot of different meshing techniques with no luck
I also know the "floating point f" error can be because of lost units...
Is there anyone that maybe can assist me in the mesh?
Thank you
hernus.groenewald@gmail.com
Hernus is offline   Reply With Quote
Old   February 21, 2014, 15:54
farzadpourfattah
farzadpourfattah is on a distinguished road
hi.
usually Floating Point relate with solution setup.
certainly you used density base solver.Do you check your Courant Number(CFL)?
first set it less than 0.5 and after some iteration increase it to 0.9 and then to 1 and bigger than 3.
farzadpourfattah is offline   Reply With Quote
Old   February 24, 2014, 12:40
Default a question
Michele
Michael-STM is on a distinguished road
Hi, can i ask you a question? what kind of setup are you using, what is the domain shape and the BC that you have used in specific...thank you!
Michael-STM is offline   Reply With Quote
bullet, farfield, inflation, magnus, meshing
table fan aerodynamic analysis using gambit and fluent ziq FLUENT 24 February 20, 2011 07:31
Aerodynamic noise analysis with CFX famarcfd Main CFD Forum 0 December 14, 2010 07:53
Aerodynamic noise analysis with CFX famarcfd ANSYS 0 December 13, 2010 06:27
Aerodynamic Analysis Simulationengineer CFX 3 October 5, 2010 20:15
Structural and Aerodynamic Analysis Márcio Lima Main CFD Forum 3 April 20, 2008 12:14
