March 5, 2014, 04:08 |
Ansys I c Engine 14.5.7
mahesh
Hii,
i am using ansys I C engine 14.5 for combustion analysis in SI engine with hydrogen blended CNG. I tried to model a geometry as like in ansys i c engine tutorial. but after importing the geometry while feeding data in property manager i got following errors.. 1. All the lift values are zero in the valve lift profile. 2. Bodies other than valves and port body are present. Unite/delete them. Actually, i am not understanding which type of geometry actually ansys needs. i tried to make it similar to the geometry as given in the ansys help. Another problem is with the syntax of the valve lift profile. please reply.... |
January 16, 2018, 00:23 |
Nick Gill
Rep Power: 8 |
I have the same error. Did you ever find a fix? |
ANSYS 14.5.7 on Opensuse!! Mission Imposible | dfeid | ANSYS | 0 | December 1, 2013 13:17 |
ANSYS 14.5.7 Installation problem on CentOS 6.4 x86_x64 machine | dfeid | ANSYS | 5 | November 29, 2013 15:50 |
Running Ansys Fluent 14.5.7 with GPU mode | rsdsaurav | FLUENT | 1 | October 21, 2013 17:57 |
Ansys 14.5.7 Structural solver | rsdsaurav | ANSYS | 0 | June 18, 2013 09:10 |
[ANSYS Meshing] 2D Jet Engine Model Creation in Ansys | vincentryan.s | ANSYS Meshing & Geometry | 0 | July 21, 2011 13:23 |
