Output Residuals in batch mode
Old   March 15, 2014, 06:08
Default Output Residuals in batch mode
pchoopanya is on a distinguished road
Dear Fluent users,
I am running a PEM fuel cell simulation in a batch mode and want to monitor the residuals. I then use the command in the journal file;
it 50
plot/residuals-set/plot-to-file res.txt
it 1
the first 50 its is to solve the problem, the last 1 it is to toggle the data to be written in the txt file... i figure this out some time ago... I do not know if this is an effective way or not, could anyone give me a clever way?
However, the problem is, with or without the last iteration, the file is an empty txt file. I even tested it by running fluent on a stand alone machine (not on HPC) and it did output the residuals data. The command is exactly the same.
I then used any plot command, like plot the oxygen mass fraction contour and output it into a txt file on batch mode, and it worked. This means, the problem is with the residuals plot command. Can you suggest?
Another question is related to licensing. I have 1 PEMFC add-on module license and the guys at HPC said we have 1 HPC pack license, and he mentioned about 8 licenses. Could you please correct me;
I understand that from a standard FLUENT ACADEMIC RESEARCH license, I can run a 4-core job. Plus 1 HPC pack which can cover 8 cores, so in total I can run a 12-core job at maximum, is this right? And what about my PEMFC add-on module license? Is 1 PEMFC license enough?
Thank you very much for any feedback, or conversations...
Regards,
Pattarapong
pchoopanya is offline   Reply With Quote
Old   March 15, 2014, 09:38
François Grégoire
macfly is on a distinguished road
Try this:
file start-transcript outputfile.txt
file read-case ...
file stop-transcript
exit yes
macfly is offline   Reply With Quote
batch, fluent, hcp, license, pem fuel cell
[swak4Foam] outputTime in Swak function immortality OpenFOAM Community Contributions 20 October 6, 2022 12:08
Running Ansys in BAtch Mode kuleuvenstudent ANSYS 1 October 18, 2017 12:11
to run a replayfile in batch mode from UNIX froztbear ANSYS Meshing & Geometry 4 May 13, 2014 08:00
How to export residuals plots data in batch mode ? Anthony Haroutunian CFX 1 March 1, 2007 16:10
Residuals batch mode JC FLUENT 0 October 20, 2003 11:14
