Simulation of a Subsonic diffuser
Old   February 2, 2017, 09:15
Default Simulation of a Subsonic diffuser
Saibal
Hello_Fluent is on a distinguished road
Hello friends,
I am doing a simulation on sub-sonic diffuser(Divergent nozzle) using ansys fluent, I am not able to get the exact result what it has to come actually.
As it is known to all of us that during subsonic flow diverging cross-section will be acting as diffuser, where velocity will decrease at the outlet and simultaneously pressure will increase.But, in my case I am getting a reverse result. Pressure is decreasing and velocity is increasing.
I am completely describing my problem details:
For the case of diffuser:
Inlet Diameter-55 mm.
Outlet diameter-110 mm.
Inlet pressure- 410043 Pascal
Inlet temperature-483 K.
Inlet gas-Air
Inlet Density-2.9563 kg/m3
Inlet velocity- 397 m/s.
As the temperature at the inlet is 483K, Mach number at the inlet is 0.9 as the velocity of sound at inlet is around 440 m/s.
During problem solving through Fluent,
I have used P inlet as the inlet boundary condition.Gauge total pressure is 693400Pascal as I found it from isentropic table corresponding to M=0.9.
Initial gauge pressure is 410043Pascal and Inlet temperature is 483K.
For the outlet case. I have used P outlet as the boundary condition and the gauge pressure at outlet is 101325 Pascal.
When I did not get the result, I changed the P outlet gauge pressure value to a higher pressure value than the Pinlet, but at that time also I found errors like reverse flow condition and divergence of the solution etc.
In the solution method I used Implicit+AUSM second order upwind scheme.
After solving this problem, I found the solution as velocity is reaching to 550m/s and the pressure is decreasing simultaneously.
Please suggest me where actually I am doing mistake, so the result is not coming properly.
Hello_Fluent is offline   Reply With Quote
high velocity flow, pressure and velocity, subsonic diffuser
restarting paused transient simulation using reactingFoam JMDag2004 OpenFOAM Running, Solving & CFD 1 August 10, 2015 10:15
Which turbulence model is applicable for Plain diffuser flow simulation in openFOAM? mukut OpenFOAM Running, Solving & CFD 4 January 30, 2015 08:06
Use homogeneous results as the initial guess for an inhomogeneous simulation JuPa CFX 5 December 26, 2014 13:44
Discrete event simulation vs. fixed time (discrete time simulation) jenjon FLUENT 0 March 10, 2013 06:58
Solver For low subsonic speed simulation firda FLUENT 0 January 28, 2011 07:45
