Steady State Solution animation
Old   April 18, 2014, 14:59
Default Steady State Solution animation
rmageddon is on a distinguished road
Hi guys,
I have been trying to mess around for days in both Fluent and CFD post but I haven't been able to figure out a solution as of yet. I have solved a steady state setup which gave me a semi periodic coefficient of drag, but that's not the issue. I had the solver save data every 10 iterations from 0 to 2000 so i have various contours I would like to animate as the solution progresses. The problem is that I can't seem to bring them into CFD post because when I try loading the case with the solution history box checked, it tells me that it cannot find the data for "blank blak" file. I can load each file individually into FLUENT and take a screenshot of the contours but that would take forever.
Any suggestions?
rmageddon is offline   Reply With Quote
Old   April 19, 2014, 00:38
François Grégoire
macfly is on a distinguished road
It would be very easy to generate a journal file that would load each data file, plot a contour, save a picture, etc. This way you don't have to do it manually, just put some time in writing the journal file. Then you find some freeware that makes an animation from pictures.
file read-data case1.dat
display contour blablabla....
display save-picture blablabla.....
file read-data case2.dat
..and so on
macfly is offline   Reply With Quote
animation, state, steady
Solidification modelling-Continuous Casting- Steady State. lucky_m_m FLUENT 1 June 8, 2022 22:23
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
is it possible to predict how long it takes to reach steady state solution in unstead Alimohamadi_nasr CFX 4 November 11, 2013 06:11
steady state solution Far CFX 0 July 28, 2011 00:07
Steady State 2 phase problem fivos FLUENT 0 April 27, 2009 16:34
