May 7, 2014, 10:54 |
how to simulate an empty container using VOF
arrmando
Rep Power: 12 |
hi guys,
I am trying to simulate an empty container (air inside) which then is filled with water using bot inlet and outlet using Volume of fluid model. My question is Which liquid /gas should be my primary and secondary phases? also When I add the inlet velocity I can only pick Mixture instead of just water. Why is this? (I have already entered this is a 2 phase VOF). I have the same problem with the outlet I can choose air or water but I can not seem to pick one or the other. When I choose air phase, lets say for outlet all my other boundary conditions inlet and water outlet change to air phase. Is there something I am missing during setup? Why is this? Your help is greatly appreciated. Best regards, AA |
HELP! adding a mass source to VOF eqn. by UDF??? | ROOZBEH | FLUENT | 5 | December 3, 2016 17:53 |
a problem of incompressible two phases(water and gas) with VOF Method | zhangweisnoopy | Main CFD Forum | 9 | August 12, 2011 08:25 |
can VOF simulate 3 phase fluid?should i use UDF?? | sincity | FLUENT | 0 | July 18, 2011 07:53 |
Question:Considerations about the evaporation in VOF | dokeun | FLUENT | 10 | February 24, 2011 20:47 |
Difficult BCs about Freesurface Simulation by VOF | Yongguang Cheng | FLUENT | 0 | September 19, 2003 07:39 |
