Large length scales
Old   May 16, 2014, 11:09
Default Large length scales
Ava
AvaShahrokhi is on a distinguished road
Hi every body
I am doing wind resource assessment in a urban area around a couple of buildings. I will be using LES for turbulence simulation and upstream wind data from meteorological measurements including wind profile and length scale.
The dimensions of the computational domain that I am simulating is 212 mx163m x 89m (in streamwise, spanwise and normal directions). This is while the length scale profile that I have been given changes from around 2 (close to the ground) up to 90 m.
Do you think that such a big length scale can cause numerical instabilities (and probably divergence) in my solution)?
my other question is that I am trying to generate structured mesh using ansys/icem around the buildings as I guess it is more robust and can provide more accurate results for LES simulations but it is really time consuming. Will I pay a big penalty if I switch to unstructured mesh? would unstructured mesh influence the convergence of the solution?
thank you very
AvaShahrokhi is offline   Reply With Quote
[ICEM] Very Different Length Scales mannobot ANSYS Meshing & Geometry 27 June 21, 2011 13:07
LES on a scaled geomentry (Mesh and Large scales) comb Main CFD Forum 0 February 8, 2011 06:21
Getting Filter Length scales CFDtoy Main CFD Forum 0 February 15, 2008 11:53
Getting Filter Length scales CFDtoy Main CFD Forum 0 February 15, 2008 11:39
length scales in turbulence bajjal Main CFD Forum 9 May 24, 2006 02:19
