May 13, 2014, 06:54 |
cooler heat input
Dinesh Balaji
Rep Power: 13 |
I need to input negative heat flux for the cooler. But unfortunately the simulation produces erratic results. when i give very low temperature as input is works fine. but my input has to be given in terms of heat flux. Can anyone suggest on how to input negative heat flux? |
May 13, 2014, 08:47 |
Flavio
Rep Power: 15 |
Hello DineshramBalaji,
can you post some picture of your problem? what kind of wrong results the simulation gives you? Regards
Bionico |
May 13, 2014, 11:50 |
Ali Jafarizade
Rep Power: 17 |
hi agree with DineshramBalaji
it's better you post or give some mor details regards |
May 16, 2014, 22:12 |
Dinesh Balaji
Rep Power: 13 |
my total heat input is 350 W/m2 through the seven servers at the top. I needed to cool off the entire heat using the cooler at the bottom. So I gave -350 W/m2 as cooler input. it is a recycling air, so there is no inlet or outlet. The operating temperature is 295 K. But the static temperature contour plot is at 2K as shown in the static temperature contour plot. Can you suggest what is the error in it? |
May 17, 2014, 08:04 |
Ali Jafarizade
Rep Power: 17 |
hi
i think its better for you to input the constant surface temperature as the boundary condition term. best regards Ali |
[OpenFOAM] Paraview 3.98 - errors when saving geometry file | pajot | ParaView | 1 | September 28, 2013 10:45 |
Help !!! : Computation/Calculation of Heat flow through several layers of Glazing | glazing | Main CFD Forum | 5 | October 12, 2010 06:28 |
Input heat source (heat/unit volume) in 2D | Polly | FLUENT | 2 | March 18, 2005 01:04 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
VISCOUS heat dissipation | Joseph | CFX | 0 | October 1, 2004 08:52 |
