Having trouble making an ogrid?
Old   June 13, 2014, 22:00
Default Having trouble making an ogrid?
Joshua Aviles
JAviles is on a distinguished road
I am attempting to model fluid flow past a cylinder within a wind tunnel scenario. So far, I have already finished meshing (as far as I know) but I am now making an O-grid. However, the O-grid is failing to be made and I am not sure as to what I am doing wrong. I simply marked the blocks within the cylinder and the blocks in the area underneath the cylinder's 2-D profile which is the solid that the fluid is passing past. I will attach an image to show the scenario.
Thank you.
JAviles is offline   Reply With Quote
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 03:30
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 12:41
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 13:59
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
