June 16, 2014, 04:12 |
Plate and tube heat exchanger simulation
jatin kumar
Rep Power: 12 |
Dear
I am working on the flow simulation of heat transfer in "Plate and Tube HX" in Fluent (Will use this idea for Shell and Tube HX simulation) I have created the model in CREO-PTC s/w and imported the ".stp" ; ".x_t" and "igs" in the Fluent module of Ansys. But while Going to "setup" of Fluent, it is showing the error of "Unassigned Interface zone detected". I had created the Named Selection of Interface, [/B]Inlet, outlet as it required for flow simulation. But do not know whether the problem is with Missing feature of imported file, if any. plz suggest me some solution to this. Thanks in advance Jatin |
interface problem, sthx fluent simulation |
Fluent 14.5 Help (Heat Transfer) | har1s | FLUENT | 0 | March 29, 2014 04:37 |
Heat Exchanger Resistance | cfdonline10 | System Analysis | 1 | June 28, 2013 07:26 |
Free stream temperature in tube wall | saharesobh | FLUENT | 2 | November 19, 2012 07:32 |
Hydraucone Draft Tube CFD | tojoe999 | OpenFOAM | 0 | March 5, 2012 13:10 |
Heat transfer | csmistry | CFX | 1 | August 20, 2009 18:39 |
