Results for Surface heat Transfer Coeff.
Old   July 2, 2014, 02:29
Default Results for Surface heat Transfer Coeff.
jatin kumar
jatin is on a distinguished road
Hey Friend
I am doing a Heat transfer analysis of Shell and tube HX (using hot and cold water)
The geometry file imported has 5 parts, Shell cover(sc), Shell fluid (sf), Baffle and tube sheet (bts), Tube Fluid (tf) and Tubes.
After Doing meshing and solving in Fluent setup for 50 iteration (although solution not converged) with energy equation ON, the fluent report shows these results for SURFACE HEAT TRANSFER COEFFICIENT (h).
plz tell me, HOW TO READ OR INTERPRET THESE RESULTS.
Plz see the attached image.
Note: Here "tf with bts" and "tf end with tubes ends" etc. are the contacts b/w these parts. (src=source and trg = target).
THANKS
File Type: jpg Tubes results for Surface HT coeff..jpg (22.7 KB, 10 views)
jatin is offline   Reply With Quote
coefficient, fluent, interpret, results, surface
Heat transfer coefficient - what is waht Stan FLUENT 28 December 29, 2021 16:29
High values of heat transfer coefficient for laminar flow in pipe Allankey CFX 2 May 28, 2014 12:44
Heat Transfer mechanisms tafaugl CFX 1 November 7, 2012 18:46
Heat Flux at wall in a conjugate heat transfer problem Chander CFX 2 July 9, 2011 22:22
Question on heat transfer coefficient!!! Benny FLUENT 7 June 7, 2005 09:25
