Heat exchanger - crazy temperature
Old   July 3, 2014, 07:11
Default Heat exchanger - crazy temperature
Dawid
torkness is on a distinguished road
I want to simulate heat exchanger. Model pipe in pipe. I want to air flowing with 40°C in inside pipe and air 900°C i outside pipe. What i get is... weird.
I don't know where the problem could be.
Those are setting i made:
-Model: Energy On, Viscous Laminar
-Cell Zone Conditions: Materials inside pipes air, materials of pipes solid aluminium
-Boundary Conditions: inlets of hot/cold pipes are set up on massflow inlet, 0.01kg/s and 900°C/40°C temperature
oulets are set up to outflow
I am learning fluent for 2 months and maybe i am doing something stupid (and simple i hope so).
Yours faithfully,
Dawid Pogorzelski
torkness is offline   Reply With Quote
Old   July 11, 2014, 11:37
David
GM_XIII is on a distinguished road
At first, i think it could probably be mesh-related, your mesh seems course. What are the dimensions of your problem? The residuals have reached convergence? You could give us a little sketch. Check also again your BC, it is a good practice.
Regards
GM_XIII is offline   Reply With Quote
Old   July 17, 2014, 08:28
Dawid
Hello, thank You for reply. I have changed mesh size. Now elements are much smaller. Unfortunately it didn't change anything. This is 2D problem. I think residuals have reached convergence. What kind of sketch do you mean? Project? I have checked my BC many many times
here is link to my project
project It is created in asnys workbench 14.
I hope together we will find solution
Old   July 18, 2014, 07:18
David
I meant a simple drawing with your bounday conditions and how you have set them up in Fluent.
pd: Also post here your residuals and the result of the new mesh
Old   August 1, 2014, 07:55
Dawid
ok, i am not sure but i have found reason. It could be velocity inlet sot up i diffrent direction than normal to boundries. So far is good. I hope nothing more will get crazy from now. Thank you for your patience and help
Old   August 5, 2014, 04:48
Dawid
Hello again,
After little succes in 2D simulation(based on your help) I decided to create 3D simulation. And again i have strange temperatures. Before (it's shame, i know) the problem was boundary conditions (direction of specification method wasn't normal to boundry). Now i have different problem. In "hot entry" i have great 1013K and in "cold" entry i have beatiful 313K. The problem is that i have 4,83e3K in couple points on "out" wall, and somewhere -14K. I did this time everything as in 2D simulation. I hope it's some stupid and easy mistake but i don't know where to look for it. Please help?
Here are:
-main problem, weird temperatres on surface of inside pipe:
-mesh (with highlighted inner pipe)
-residuals (first 100 are for laminar viscous model, after is standard k-e)
-my boundary conditions
Old   August 5, 2014, 09:36
ghost82's Avatar
Rick
ghost82 will become famous soon enough
Hi, it's clear from the residual image that solution is not converged.
Why don't you setup a structured hexa mesh? It is quite simple for your geometry.
ghost82 is offline   Reply With Quote
Old   August 6, 2014, 21:13
Sangwoo Kim
swtbkim is on a distinguished road
Are you going with steady solver?
You should use unsteady solver when handling heat transfer problem
Best regards
swtbkim is offline   Reply With Quote
[openSmoke] libOpenSMOKE Tobi OpenFOAM Community Contributions 562 January 25, 2023 09:21
convergenceof natural convection prob. in cfx cpkewat CFX 15 January 31, 2014 06:29
Radiation interface hinca CFX 15 January 26, 2014 17:11
2D heat exchanger problem Kwiaci FLUENT 0 June 7, 2012 07:12
Recommendation for CFD software james15 Main CFD Forum 11 May 19, 2011 08:32
