DPM cloud size and domain size dependency
Old   April 19, 2015, 16:50
Default DPM cloud size and domain size dependency
MK
MateuszK555 is on a distinguished road
I'm new to DPM modelling.
My project contains the domain 2.5x3x6 [m] with an inlet in the center of 2.5x3 [m] surface. Inlet d=0.003 [m]. I need to simulate the injection of water particles into the domain of air to determine the distribution. I am injecting the particles from inlet surface (d=0.003m) and the same surface is also velocity inlet v=200m/s. Rest of the boundaries of the domain are pressure outlets with 0 gauge pressure. I am using the breakup model. Turbulence model - k-epsilon standard wall function. Drag model for the particles is dynamic-drag. Uniform temp. 300K.
My DPM settings are:
1. inject DPM every 5 iterations of continuous phase
2. particle time step size 0.0005s and number of time steps 1
3. tracking: number of steps 600 and length scale 0.01m
My results after 1000 iterations look like this (attachment 1.jpg)
The cloud is not covering the whole domain.
Is the iterations number 1000 enough ?
Is this the physical behavior of the presented phenomena that the cloud is not reaching the whole domain?
Which settings can I manipulate to tweak with the distribution in order to cover the whole domain ?
Thanks for your time and help,
Mateusz
MateuszK555 is offline   Reply With Quote
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
How to increase domain size for validation Zonexo Main CFD Forum 8 November 18, 2008 01:22
Size of rotating domain Adam CFX 4 November 28, 2006 10:28
Diverging wall scale due to large domain size Kevin CFX 3 November 12, 2006 15:48
