July 29, 2014, 09:13 |
Pressure Coefficient in wind turbine
I am simulating the NREL phase VI experiment and i want to compare the pressure coefficients at specified location along blade span with the experiment result. I plotted the pressure coefficient at a specified iso-surface but the results are very far from the experiment. The question is is it correct to use directly the pressure coefficient in the x-y plot menu or should i use another formula. Thanks in advance |
Difficulty in calculating angular velocity of Savonius turbine simulation | alfaruk | CFX | 14 | March 17, 2017 06:08 |
Contour of Pressure Coefficient and Velocity Vectors Colored by Pressure Coefficient | sonam | OpenFOAM | 0 | August 2, 2012 00:16 |
Automotive test case | vinz | OpenFOAM Running, Solving & CFD | 98 | October 27, 2008 08:43 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 22:02 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
