turbulent viscosity ratio for jet
Old   January 14, 2006, 17:49
Default turbulent viscosity ratio for jet
serpil
Hi everybody, I try to model an axisymmetric jet behind a turbofan exhaust. The problem is that with RANS the turbulent vicosity ratio is on the order of 10e4 which seems to be high physically. There exist two stream; one with Mach 0.4, and corresponding 10% turbulent intensity, and the other with mach 0.2 and 6%turbulence intensity. Is that much turbulent viscosity physical? If not, what can be the reason for that?
Thanking to everyone in advance for time and consideration.
Old   January 17, 2006, 11:23
Default Re: turbulent viscosity ratio for jet
J. Kim
You may have some answers through searching this website.
My suggestion is as follows:
Test your problem by reducing the jet velocity (around 1/100 scale). If you still have the same problem, insert more meshes. or Remesh your domain.
You may try the following schemes together;
Lower relaxation factors, Use different initialization values, Start unsteady simulation at first.
Old   January 17, 2006, 13:51
serpil
Dear Kim, thanks a lot for your comments. I will consider your advice.
Old   September 19, 2014, 06:19
RSS
rachitsigh11 is on a distinguished road
Hi serpil..........i am doing simulations for normal shock at Mach = 2 at high altitudes. But i am not able to find what the value of turbulent viscosity ratio would be at such high altitudes and high reynolds number. Can u give some reference for find the value of turbulent viscosity ratio.
Also how u got this value " with RANS the turbulent vicosity ratio is on the order of 10e4". Thanks
rachitsigh11 is offline   Reply With Quote
hel (turbulent viscosity ratio limited) for supersonic combustion problem omar.2002bh FLUENT 2 September 5, 2012 11:04
setting value of turbulent intensity and turbulent viscosity ratio in wind tunnel nuimlabib Main CFD Forum 0 August 4, 2009 00:05
On limiting to turbulent viscosity ratio! varghese FLUENT 2 November 15, 2003 08:56
Problem of Turbulent Viscosity Ratio Limited David Yang FLUENT 3 June 3, 2002 06:13
