August 6, 2014, 10:05 |
Fluid-Solid-Fluid Zone
Luis Delgado
Rep Power: 12 |
Hi, I want to simulate a water flow through a pipe of steel, which is inside a tank of water. I think is not necessary to do the geometry of the pipe, so how can I do to represent the interface between the two fluid zones like the solid wall?
I need somebody help me please. Thanks. |
fluid-solid-fluid-solid, interface domains |
Heat Transfer from Solid to Adjacent Solid and then to Adjacent Fluid | dkx209 | FLUENT | 1 | July 18, 2013 09:50 |
goddamnit: how to set up heat transfer from fluid to solid | macfly | FLUENT | 7 | June 16, 2012 11:50 |
Segmentation Fault in fluent3DMeshToFoam | cwang5 | OpenFOAM Bugs | 23 | April 13, 2011 15:37 |
Problem in IMPORT of ICEM input file in FLUENT | csvirume | FLUENT | 2 | September 9, 2009 01:08 |
Sliding mesh error | Karl Kevala | FLUENT | 4 | February 21, 2001 15:52 |
