Modeling gas expansion in vacuum
Old   August 19, 2014, 11:46
Post Modeling gas expansion in vacuum
rcd
cryonole is on a distinguished road
I am new to FLUENT and want to know if gas expansion in a vacuum tube can be modeled using it. The geometry is similar to a shock-tube but with a state of vacuum in the 'driven' section and finite pressure in the 'driver' section. I want to determine the transient pressure/density/velocity field in the tube when the diaphragm separating the finite pressure and vacuum sides is suddenly ruptured.
cryonole is offline   Reply With Quote
Old   August 21, 2014, 04:41
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
Did you think about whether CFD is capable of doing this at all? I mean, if you have a (nearly-) vacuum on one side the Knudsen number will be pretty high there. Maybe CFD equations aren't valid there...
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   August 21, 2014, 10:19
pakk will become famous soon enough
I think you can model it, and the results will be reasonably reliable.
RodriguezFatz is correct, if it is really vacuum on one end, then the continuum hypothesis fails there, and your equations will be incorrect. But because the majority of the mass will be in the region where the continuum hypothesis is valid, your results will generally be OK-ish. How good it is, depends on what you want to get out of your model. If you want to know the shockwaves that go back into your high-density part, you are safe, I think. If you want to see exactly what happens on the front of the shockwave into the vacuum part, you will not get a good answer. The order of magnitude of the shockwave velocity will be correct, but can be off by 50%.
Some parts of your transient pressure/density/velocity field will be accurate, some will not. In general, the parts in the vacuum will be less accurate.
If you want to simulate this in Fluent, make sure to use the density-based solver.
pakk is offline   Reply With Quote
expansion, fluent 12.0, vacuum
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
error message cuteapathy CFX 14 March 20, 2012 06:45
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
modeling gas expansion queequeg FLUENT 0 June 19, 2010 01:04
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 22:02
