Animations with moving reference frame(MRF)
Old   August 24, 2014, 20:58
Question Animations with moving reference frame(MRF)
MarkClarence
Clarence91 is on a distinguished road
I could make movies using dynamic mesh motion by saving the case-data files in tecplot format.
And I was wondering is there a way to save the MRF case and data files wherein we can visualize the motion of the geometry?
Eg. In sliding mesh motion or dynamic mesh motion, we can save the case and data files with AUTOMATIC EXPORT option and make movies showing the rotion of the rotor or whatever. Similarly is there a way to save the case-data files, so that even with MRF option, we can visualise the motion in geometry and make movies out of it?
Thank you
-Mark Clarence
Clarence91 is offline   Reply With Quote
Old   August 25, 2014, 03:28
Cees Haringa
CeesH is on a distinguished road
The rotor doesn't move in MRF, how do you want to visualize that?
CeesH is offline   Reply With Quote
Old   August 25, 2014, 03:31
amine
aminem is on a distinguished road
Hi
In MRF your rotor don't move.
Good luck
aminem is offline   Reply With Quote
Old   August 25, 2014, 11:13
MarkClarence
whether its dynamic mesh motion/MRF....rotor rotates.
Only thing is the position of axis.
In dynamic mesh motion, the axis will be away from geometry so we are able to visualise it. In case of MRF...its something like your position is over the geometry and when you are rotating the rotor it means even you are rotating with the rotor simultaneously.
Eg. If you are sitting in a bus and the bus is moving with 60miles/hr then you wouldnt know the speed of the bus(MRF)
If your are standing outside the bus then you will be able to know the speed of the bus. (DYNAMIC MESH)
Old   August 25, 2014, 13:12
ghost82's Avatar
Rick
ghost82 will become famous soon enough
In any case you will never be able to visualize rotor motion with mrf, since your mesh is static.
As other people said, the only way to animate the rotor is to use dynamic mesh.
ghost82 is offline   Reply With Quote
Old   August 25, 2014, 13:17
MarkClarence
I created animations using dynamic mesh.
My advisor told me that there would be some keywords or commands to save case-data files even for FRAME MOTION where we can visualize rotation of the rotor.
Old   August 25, 2014, 13:42
ghost82's Avatar
Rick
I never heard about possibility of animating a moving rotor (mesh) in a steady state solution (mrf); but a quick search in google shows that ensight post processing software can couple the rigid body motion to the steady solution and make the rotor move!
https://www.ceisoftware.com/cfd-post-processing-of-mrf/
But I don't think that fluent has that feature to animate a mrf solution..maybe I'm wrong..
Old   August 25, 2014, 14:50
MarkClarence
Thanks for the reply.
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 00:58
WallHeatFlux and chtMultiregion m_f OpenFOAM Post-Processing 13 March 16, 2015 10:16
LiencubiclowRemodel nzy102 OpenFOAM Bugs 14 January 10, 2012 08:53
compile error about FJMPI chiven OpenFOAM Installation 11 March 31, 2010 06:27
Help for Moving Reference Frame. aiqch Main CFD Forum 0 April 3, 2009 00:23
