What to set the turbulence specification of airfoil
Like Tree2Likes
  • 1 Post By blackmask
  • 1 Post By Far
Old   March 9, 2013, 01:11
Default What to set the turbulence specification of airfoil
Wheeler
shlgzz is on a distinguished road
Hello,everyone.I'm simulating the airfoil flow field.However,I encountered some problems.
1.What to set the turbulence specification of airfoil, modified turbulent viscosity, intensity and length scale, turbulent viscosity ratio or intensity and hydraulic diameter?
2.The material you choose is air or ideal gas?
Thank you in advance.
shlgzz is offline   Reply With Quote
Old   March 9, 2013, 06:23
blackmask will become famous soon enough
I always use the turbulence intensity and viscosity ratio to specify turbulence because they are the most apparent parameters to me. Ideal gas is one way to relate the density with other quantities such pressure and temperature and is not a kind of material. If what you meant is how to choose between constant density and ideal gas, then it largely depends on your flow Mach number.
shlgzz likes this.
blackmask is offline   Reply With Quote
Old   March 9, 2013, 07:43
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Keep the default condition if you are not trying to match some wind tunnel setup. Most appropriate parameters to me are : Turbulence intensity and length scale. While the data for turbulence intensity is available but length scale data is not. I can send you very relevant journal papers if needed.
Having said that, these parameters come into play at critical Reynolds number, otherwise default conditions should suffice.
shlgzz likes this.
Far is offline   Reply With Quote
Old   March 9, 2013, 15:22
Default daer...
farzadpourfattah
farzadpourfattah is on a distinguished road
if your mach number is:
less than 0.3, chose constant density,
bigger than 0.3 chose ideal gas.(Notice that if you select ideal gas, energy equation tuned on automatically and you should set temperature condition.
farzadpourfattah is offline   Reply With Quote
Old   March 10, 2013, 20:46
Wheeler
blackmask,thank you for your reply.Although I still have some problems on turbulence specification method, it's a matter of experience.
Old   March 10, 2013, 20:56
Wheeler
Thank you, Far.Your suggestion is useful.I really need some relevant journal papers.Could you send them to my email?
Old   March 10, 2013, 20:57
Wheeler
farza,thank you.
Old   March 10, 2013, 22:09
Far
Sijal
send your email id please
Old   August 21, 2013, 06:15
Default komega sst
sh.d is on a distinguished road
hi dear Far
i want to simulat flow around an airfoil and using komega sst model.my mach number is 0.5 and Re=30*10^6
i dont now how estimate turbulence intensity and k and omega in boundary condition?
pleas can you help me?
sh.d is offline   Reply With Quote
Old   August 21, 2013, 13:30
farzadpourfattah
use length of chord airfoil as length scale of turbulence and intensity 0.1%
Old   August 21, 2013, 13:33
Far
Sijal
Originally Posted by sh.d View Post
hi dear Far
I would suggest to use the default values if you are modeling transition or reprocuding alrady done wind tunnel experiment
Old   August 28, 2014, 10:44
cfdseeker is on a distinguished road
Hello Sijal,
I have a quesion. How can I calculat the drag coefficient from the CFD Post for FLUENT?
I have created a post here, can you commented on it please?
http://www.cfd-online.com/Forums/flu...alidation.html
Thanks
cfdseeker is offline   Reply With Quote
Old   August 28, 2014, 11:04
Default CFD Post
  #13
farzadpourfattah
Yes you can.
in expression tab you can define Drag coef:
Foorce X@airfoil/0.5*density*Velocity*Velocity*chord length*Span
Old   August 29, 2014, 06:04
Hi Farzad,
Thanks for the reply. But how come 2D smulation in FLUENT have span??
If you take "Force X/span" and evaluate expression you gave, you get cd, which is drag coefficient per span length . Will this equal to NASA data?
The same quetion I ask for lift coefficent, where Force X is replaced by Force Y.
Help is much appreciated
airfoil, turbulence, turbulence specification
Instalation on ubuntu 710 basilwatson OpenFOAM Installation 17 March 16, 2012 20:16
A huge mistake that could ruin my project: wrong turbulence specification Cheeko FLUENT 1 June 12, 2010 07:02
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
Help with GNUPlot Renato. Main CFD Forum 6 June 6, 2007 19:51
Multi-element airfoil problems.Scaling turbulence? Carlos Saraiva Siemens 0 April 10, 2003 11:21
