Use Input parameter in the monitor window drag and lift calculation
Old   August 21, 2014, 09:42
Question Use Input parameter in the monitor window for drag and lift calculation
Anna Tian's Avatar
Meimei Wang
Anna Tian is on a distinguished road
How to use Input parameter in the monitor window as shown in the picture attached?
Best regards,
Meimei
Anna Tian is offline   Reply With Quote
Old   August 23, 2014, 03:15
Question
Anna Tian's Avatar
Meimei Wang
Originally Posted by Anna Tian View Post
Could anyone answer me this question?
Best regards,
Meimei
Old   August 31, 2014, 23:24
Question
Anna Tian's Avatar
Meimei Wang
Could anyone help on this question?
Best regards,
Meimei
Old   September 1, 2014, 04:41
ringtail is on a distinguished road
As I know, there is no way to use input parameters for force monitoring directly. But if what you want is to change the parameters for force monitoring automatically, you can use journal files and scripts to conduct this.
ringtail is offline   Reply With Quote
Old   September 1, 2014, 05:33
Question
Anna Tian's Avatar
Meimei Wang
I want to use workbench to run Fluent cases and export the monitor results Cd, Cl directly from the workbench table. In this way, I can change the input parameters simply and copy large amount of Fluent simulation results from workbench to excel directly.
Best regards,
Meimei
Old   September 1, 2014, 20:44
If you just want the final result of cd, cl and so on, I mean steady simulation, the result component (actually it is cfd-post)of fluid simulation model in workbench can do it.
Lift and drag calculation Franny CFX 16 November 27, 2019 13:47
wrong SU2 calculation for lift and drag coefficient for NAC4421 mechy SU2 7 January 9, 2017 05:18
drag and lift calculation of a cylinder in wind tunnel fewgoodmen Main CFD Forum 4 February 24, 2014 15:05
Calculation of lift and drag coefficients Prachi CFX 3 August 14, 2007 14:05
lift and drag calculation actone CFX 0 December 27, 2006 17:11
