Reference value setting for mixing tank driven by rushton turbine
Old   September 11, 2014, 16:08
Default Reference value setting for mixing tank driven by rushton turbine
Eakarach is on a distinguished road
Hi, I simulate the mixing tank by using mrf method. I have some question about reference value setting as following.
1) Does the reference values setting relate to the torque or moment prediction?
2) How to setup the refernce values for rushton turbine mixing tank?
P.S. Thank in advance
Regards
Eakarach Bumrungthaichaichan
Eakarach is offline   Reply With Quote
Second Derivative Zero - Boundary Condition fu-ki-pa OpenFOAM 11 March 27, 2021 04:28
OpenFOAM-2.1.x on fedora 16 x86_64 anand_30 OpenFOAM Installation 3 December 26, 2011 02:09
[Commercial meshers] Conversion form .ccm to openFoam ViktoriaE OpenFOAM Meshing & Mesh Conversion 1 November 29, 2011 16:40
OpenFoam 1.6-ext - RPM build errors preibie OpenFOAM 12 September 8, 2011 03:12
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 21:58
