Problem simulating natural convection tall cavity |
September 24, 2014, 16:11 |
Natalia
I hope someone can help me.
I'm trying to simulate natural convection in a tall vertical annuli cavity. Height is 0.215 m, outer cylinder is 0.15 m, and inner cylinder is 0.03 m in diameter. My mesh is al hexahedral 2D, with 70700 elements. My model is 2D axysimetric. There are more than 30 elements in the region of the boundary layer. Gravity is -9.81 in X. I'm using double precision in Fluent. Pressure-based solver, steady. I'm using SST k-omega with low Re-correction. I'm doing the boussinesq approximation stating operating density and a compresibility coefficient. Fluid is water. The boundary conditions are uniform heat flux 440 w/m^2K in the inner wall and -176 W/m^2K for the outer wall. The Rayleigh number is 10^8. Scheme SIMPLE, Spatial discretization for pressure is PRESTO!, second order upwind for momentum, turbulence, dissipation and energy. All relaxation factors are default. I doesn't converge. k is constanlty diverging. I also tried transient approaches and it seems to converge only at low Ra numbers. I have tried other solvers, and other models for viscosity and nothing seems to work. Can someone give me suggestions?? Thanks in advance |
boussinesq approximation, fluent, high rayleigh numbers, natural convection, tall cavity |
convergence problem in natural convection | paps | ANSYS | 0 | December 1, 2013 05:04 |
Natural convection in cavity heated by below | Nanbrain | Main CFD Forum | 0 | January 28, 2013 07:49 |
how to set the parameters in simulating the natural convection | hook | FLUENT | 1 | January 17, 2010 01:33 |
Radiative heat transfer with natural convection inside a square cavity | msarkar | OpenFOAM | 1 | January 11, 2010 22:21 |
ON TURBULET MODEL FOR A NATURAL CONVECTION PROBLEM | varghese | FLUENT | 6 | February 6, 2002 05:23 |
