October 28, 2014, 12:11 |
Easiest way to create a LES animation?
Adnan Nweilati
Rep Power: 11 |
Hello guys,
Does anyone have an easy way to create a LES animation of the results? I was wondering if there is any way to save pictures of the results at timesteps during the run automatically? The way Im doing it now is just time consuming and takes vast amounts of storage. I save the results for every 100 iteration and load each one on them and take a screenshot. This is boring if you are doing the same thing over 40 times. Please note: I dont have any knowledge of coding. Thanks |
October 28, 2014, 15:50 |
Rep Power: 11 |
Under calculation activities you have a option for animation, simply specify all the parameters and specify where to save. Then use a program like windows moviemaker or some freeware animation to make the animation!
Hope you figure it out! |
October 29, 2014, 08:17 |
Adnan Nweilati
Rep Power: 11 |
I can't choose solution animations
Did I miss anything? *Check the screenshot attached |
October 29, 2014, 08:26 |
Rep Power: 11 |
I'd recommend the CFD-Post tool for this if you have access to it. It will load all your timesteps and make all kind of animations and plots and what not.
October 29, 2014, 15:24 |
Rep Power: 11 |
You have to initialize first, then you can set it up Or even better do as pilakin said! Hope this helps!
animation, cfd, fluent, les |
Creating animation through TUI | wawa | FLUENT | 27 | November 5, 2021 03:17 |
LES Filtering: how are the small and large scales equations solved? | atmcfd | Main CFD Forum | 38 | March 14, 2016 14:52 |
Beginning to work in LES - Suggestions needed | atmcfd | Main CFD Forum | 5 | July 20, 2012 22:16 |
create animation | Sylvain | Main CFD Forum | 2 | July 18, 2005 09:41 |
3D-2D LES | Jan Ramboer | Main CFD Forum | 8 | January 4, 2000 13:31 |
