trying to write a UDF for viscoelastic in fluent
Old   October 27, 2014, 20:35
Default trying to write a UDF for viscoelastic in fluent
Tejasvi Krishna
tejasvikrishna is on a distinguished road
Send a message via Skype™ to tejasvikrishna
Hey,
I have been trying to write a UDF for viscoelastic in fluent for which I need to solve for the conformation tensor simultaneously with the momentum conservation...
for which I need to new scalars... I have written the code but I am having a horrible time to compile it..
Please look at the code and let me know, what is it that I am doing wrong! ...
real x[ND_ND];
face_t f;
real diff;
real source, lamda ,fn, L , R;
lamda = 0.01;
L = 10;
DEFINE_ON_DEMAND(rename_UDvars)
Set_User_Scalar_Name(0,"UDS0: C11");
Set_User_Scalar_Name(1,"UDS1: C12");
Set_User_Scalar_Name(2,"UDS2: C13");
Set_User_Scalar_Name(3,"UDS3: C22");
Set_User_Scalar_Name(4,"UDS4: C23");
Set_User_Scalar_Name(5,"UDS5: C33");
Set_User_Scalar_Name(6,"UDS6: C21");
Set_User_Scalar_Name(7,"UDS7: C31");
Set_User_Scalar_Name(8,"UDS8: C32");
Set_User_Scalar_Name(9,"UDS9: tau11");
Set_User_Scalar_Name(10,"UDS10: tau12");
Set_User_Scalar_Name(11,"UDS11: tau13");
Set_User_Scalar_Name(12,"UDS12: tau22");
Set_User_Scalar_Name(13,"UDS13: tau23");
Set_User_Scalar_Name(14,"UDS14: tau33");
Set_User_Scalar_Name(15,"UDS15: tau21");
Set_User_Scalar_Name(16,"UDS16: tau31");
Set_User_Scalar_Name(17,"UDS17: tau32");
I follow that up with the governing equations
DEFINE_SOURCE(C11_source,c,t,dS,eqn)//source term of uds equation
C_CENTROID(x,c,t)
R = sqrt(C11(c,t)+ C22(c,t)+ C33(c,t));
fn = (L*L-3)/(L*L-R*R);
Source = C11(c,t)*C_U_G(c,t)[0]+ C12(c,t)*C_U_G(c,t)[1]+ C13(c,t)*C_U_G(c,t)[2]+ C11(c,t)*C_U_G(c,t)[0]+ C21(c,t)*C_U_G(c,t)[1]+ C31(c,t)*C_U_G(c,t)[2]- 1/lamda*(f*(C11(c,t));
dS[eqn]=2*C_U_G(c,t)[0]-1/lamda*(-f^2/(L^2-3)*(2*C11(c,t))*(C11(c,t)-1)+f);
tau11(c,t) = myu_P/lamda*(f*C11(c,t)-1);
return source;
Thankyou for you time ...
tejasvi
tejasvikrishna is offline   Reply With Quote
Old   October 28, 2014, 03:46
pakk will become famous soon enough
It would help if you would give the error message that you get when compiling.
Nevertheless, the problem could simply be that you use "Source" where you should use "source".
pakk is offline   Reply With Quote
Old   November 3, 2014, 17:01
Tejasvi Krishna
Thank you for your reply.... thankyou for pointing out that mistake... I corrected it and when I try running it ... it still says error in line 2 ... and would not tell me any more specifics
Old   November 4, 2014, 08:16
Paritosh Vasava
vasava will become famous soon enough
If you are looking to make a new viscosity model then you need to use DEFINE_PROPERTY macro.
vasava is offline   Reply With Quote
looking for a smart interface matlab fluent chary FLUENT 24 June 18, 2021 09:07
Fluent UDF for thermal NOx larsschwarzer Fluent UDF and Scheme Programming 1 July 18, 2014 08:39
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 22:56
Fluent write UDF for calculating My, Mz and Fz davesmith_01 FLUENT 1 November 20, 2011 21:20
fluent UDF external library lapack problem Rick FLUENT 0 May 7, 2008 10:16
