static pressure in water wheel
Old   November 12, 2014, 11:19
Default static pressure in water wheel
Ema40 is on a distinguished road
Hy everybody.
I am simulating a water wheel with an angular velocity v [rad/s].
If there is no water, the static pressure is only due to the air weight, so it increases from the top of the wheel toward the lowest point of the wheel (since the air is lightweigh the difference of static pressure has to be small, but if I plot it the difference is 300 N/mq!! And the wheel is only 2 m in diameter.
Anyone can help me?
Thank you
Ema40 is offline   Reply With Quote
rotating domain, static pressure, turbine, water wheel
Discrepancy between the measurements (pressure drop; VOF) blackemperor FLUENT 2 March 6, 2016 03:40
Assign static pressure at inlet Tanjina FLUENT 0 November 3, 2013 11:34
defining a term for a domain using DEFINE_ADJUST MASOUD Fluent UDF and Scheme Programming 1 September 24, 2010 05:08
Average static pressure BCs and aircore in cyclone KM CFX 2 December 17, 2007 20:50
hydrostatic and static pressure pi CFX 3 May 26, 2004 10:35
