Tank emptying problem using Ansys Fluent
Old   November 12, 2014, 16:54
Default Tank emptying problem using Ansys Fluent
Tanjina Afrin
Tanjina is on a distinguished road
I am modeling a reservoir-pipe system, where with time water from reservoir will drain out through pipe. I am using Ansys Fluent. I think it's pretty common simulation.
But I have one confusion. For top of the reservoir, what BC should I use ? Wall BC ( I assigned one zone above the top of the reservoir ar patched that zone with air) , or should I use pressure inlet and allow air to enter ?
Any suggestion will be highly appreciated.
Regards,
Tanjina
Tanjina is offline   Reply With Quote
Old   November 13, 2014, 04:14
ghost82's Avatar
Rick
ghost82 will become famous soon enough
What does it happen when you are drinking something with a straw, you have the straw full of liquid, you plug one extremity of the straw with a finger and you rise it from the glass?
PS: finger is the wall, straw is the reservoir
Google is your friend and the same for the search button!
ghost82 is offline   Reply With Quote
Old   November 13, 2014, 07:04
pilakin is on a distinguished road
I'm working on an emptying tank, too, and while it seems obvious at first it's a actually quite a problem to simulate. you have to either use a two-phase model with water and air and possibly evaporation or you can use a wall with slip for the top reservoir boundary, if the vapor above the water is of no interest to you. however, you will have to move this wall as the water flows out with a dynamic mesh. depneding on geometry and mesh you'd need to code more or less complicated UDFs.
pilakin is offline   Reply With Quote
Old   November 13, 2014, 09:58
Tanjina Afrin
Thanks guys for replying.
@ Pilakin,
Yup, I am using VOF model. Is it that much complicated that I have to use dynamic mesh and UDF !!
I tried with both BC as I said in my previous thread .... using the no slip wall BC (I used one zone of air which is in between the top wall and water surface to make atmospheric pressure on water surface), I found that water level is not falling with time, instead of that air is entering from outlet and it goes to upstream !!
And with pressure inlet with air entering, I found water level is dropping with time. It seems reasonable to me, but one thing makes me confused. I am simulating another model at the same time with perforated pipe and water comes to the pipe from top. In that model, I used wall BC at the top and assigned a air zone between top wall and water surface. In this model, water is dropping and at the same time air is entering from outlet.... I can't explain this two phenomena
@ghost82, I am getting properly what you are saying ....could you please explain ?
Regards,
Tanjina
Old   November 13, 2014, 10:21
ghost82's Avatar
Rick
What I meant is that if you put a wall above the water level with air trapped between the free surface and this top wall, gravity will push down the water but if you are not letting air to enter it will be created vacuum and water will not drain!
So your top surface is a pressure inlet, so to let air to enter your domain from the top.
Old   November 13, 2014, 10:38
Tanjina Afrin
Thanks Ghost. I can understand clearly. Yup thats what I saw that water level was not dropping. But why is was dropping for my other model? Do you have any idea ? I am attaching a contour of my second model at 14s. around the pipe , zone was gravel zone, so water-air interface is not that much clear.
Old   November 13, 2014, 10:41
ghost82's Avatar
Rick
Sorry, but I cannot understand clearly the contour plot: can you elaborate a bit more and specify bc?Can you specify where water exits/air enters?
Old   November 13, 2014, 11:05
Tanjina Afrin
I a attaching a new image. hope now you'll get a clear image.
Old   November 13, 2014, 11:11
Tanjina Afrin
Sorry, I didn't attach image with previous thread.
Old   November 13, 2014, 11:17
ghost82's Avatar
Rick
The setup doesn't seem correct to me.
Correct setup should be pressure inlet for the top horizontal surface even in this case.
Are you sure these are converged solutions?
Old   November 13, 2014, 11:21
Tanjina Afrin
Yea, it is converged solution.. it's running for 300s ( up to today-it took more the one month to get these 300sec data)
I was trying to run a model which is exactly this one but length of pipe is smaller with pressure inlet, but two time that model collapsed! so I am getting more confused.....
Old   November 18, 2014, 10:54
Tanjina Afrin
Hello Ghost82,
If I assign symmetry BC instead of pressure inlet I find the same phenomena as using wall BC i.e. water level is not dropping, air enters from outlet.... what can be the possible explanation? Symmetry BC can make the constant water level ?
Old   November 18, 2014, 11:07
ghost82's Avatar
Rick
Yes, symmetry at top means air cannot enter the domain from the top, so vacuum is created and water cannot drop.
You can think symmetry boundary condition as a zero shear slip wall.
Directly from the user guide:
ANSYS FLUENT assumes a zero flux of all quantities across a symmetry boundary. There is no convective flux across a symmetry plane: the normal velocity component at the symmetry plane is therefore zero. There is no diffusion flux across a symmetry plane: the normal gradients of all flow variables are therefore zero at the symmetry plane. The symmetry boundary condition can therefore be summarized as follows:
  • zero normal velocity at a symmetry plane
  • zero normal gradients of all variables at a symmetry plane
Old   January 1, 2023, 07:22
Shamoon Jamshed
Shamoon Jamshed is on a distinguished road
Send a message via Skype™ to Shamoon Jamshed
Dear Ghost!
I have seen two kinds of tutorials for emptying tank. One is considering pressure outlet at the reservoir end and one with pressure inlet. Which condition works best? I have applied both but the tank water is not moving a mili meter even. For pressure outlet at the drain side, the backflow volume fraction is 1. In case, if I apply pressure inlet, what about supersonic/initial gauge pressure? by default, everything is zero.
Regards,
SJ
Shamoon Jamshed is offline   Reply With Quote
Ansys 12.1 - Create Rotor/Stator Interface for Fluent opm ANSYS Meshing & Geometry 21 May 23, 2016 08:29
problem in using parallel process in fluent 14 aydinkabir88 FLUENT 1 July 10, 2013 02:00
Can I solve this problem by Fluent? Kai_kc FLUENT 1 October 27, 2010 05:29
Fluent & Ansys FSI architecture help DillonS FLUENT 1 April 7, 2010 16:00
Can FLUENT solve this type of problem? Whitaker FLUENT 3 October 23, 2000 03:01
