NACA 0012 (3D) strange results?
Old   December 19, 2014, 11:39
Default NACA 0012 (3D) strange results?
aleix de toro diaz
aleix.de.toro is on a distinguished road
Hi friends!
Im new on this forum, I've started learning fluent because i need to make a final project designing a plane for my final degree.
I am starting with a NACA 0012 (in 3d ). Firstly i am introducing a velocity inlet of 30 m/s, and inviscid flow model.
I have done it with 0 AngleOfAttack ( on boundary conditions X=-30 m/s)
With 5 AOA (X=-30 cos (5), Y=0, Z=-30sin (5))
and with 10 AOA (X=-30cos(10), Y=0, Z=-30sin(10))
I have attached 3 plots of velocities for the three angles, I think it is really strange that the stagnation point (where the velocity is 0 m/s), when I change the angle of attack does not varies. Are these results bad?
The other two plots show the coefficients of pressures around the naca (for this part I have created an Iso surface, selecting mesh and Y coordinate from the airfoil surface). For the results, I think there is almost no difference and it should be more difference.
Moreover, the results for 5 AOA (Cd=0.027117317 and Cl=0.30893708)
10 AOA (Cd= 0.10493012 and Cl=0.59508828 )
I think that the value of the Cd (0.10492012) is not very reasonable.
What do you think about the results?
Thank you
aleix.de.toro is offline   Reply With Quote
2D NACA 0012 Airfoil Validation Case (NASA) jp3g12 OpenFOAM Running, Solving & CFD 24 April 23, 2021 14:34
Simulate NACA 0012 Wing nvtrieu FLUENT 20 February 7, 2016 10:54
How to import NACA 0012 Profile in Gridgen maplepink Main CFD Forum 17 May 7, 2013 13:01
NACA 2408 Comparative results. Saran1991 Main CFD Forum 4 January 22, 2013 12:44
NACA 0012 simulation results Luis FLUENT 3 February 15, 2006 11:42
