trying to find the center of pressure of stratosail
Old   December 30, 2014, 11:17
Default trying to find the center of pressure of stratosail
Jayakanth is on a distinguished road
Hi guys,
I want to calculate the center of pressure of a stratosail body at different angles of attack. I have read through some of the posts, but I cant seem to get a clear step by step guide on this.
Is it possible to print the coordinates of the centre of pressure? I have tried setting x=0 and then printing the other 2 coordinates. But, I do not understand this method.
Alternatively, how can I calculate the moment due to the resultant drag force about the center of mass? The manual says that you will need a moment center and a moment axis. I guess the moment center will be the center of mass of the sail. But, why do you need a moment axis?
Rgds
Jay
Jayakanth is offline   Reply With Quote
Old   December 30, 2014, 14:20
Lucky
Moments are always about an axis. A center (location) alone does not define the axis about which the moment is considered. The question is why you would think you can have a moment without any axis?
If the center is at the origin. Your moment axis could still be any axis, (x,y,z, or any other axis). You must also specify what is the axis with respect to which you are going to define your moment. In other words, you need a point (a location) and a direction vector to define the axis and only after that is fully defined can you consider any moment.
Old   December 31, 2014, 05:58
So specifying the moment axis tells fluent to compute the moment along that specified axis. So, if the moment had components of x,y and z, then if i specified the moment axis as (1 0 0), it would compute the moment along the x-axis?
What about printing the coordinates of the center of pressure? What are the steps for that?
Rgds
Jay
Old   January 2, 2015, 06:37
Rgds
Jay
Anyone can verify this?
Rgds
Jay
[ANSYS Meshing] Help with element size sandri_92 ANSYS Meshing & Geometry 14 November 14, 2018 07:54
question regarding LES of pipe flow - pimpleFoam Dan1788 OpenFOAM Running, Solving & CFD 37 December 26, 2017 14:42
How to find the coordinates of center of pressure Alexey Siemens 0 February 1, 2007 10:37
Center of Pressure Astrid CFX 0 December 21, 2006 04:07
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
