air flow through nozzle like structure
Like Tree2Likes
  • 1 Post By MB72
  • 1 Post By MB72
Old   January 11, 2015, 05:07
Default air flow through nozzle like structure
Praroop Jain
praroopjain is on a distinguished road
Actually I am simulating the air flow from a nozzle like structure and I get these results. (shown in screen shot)
the velocity at the end point is nearly 1k kmph if the velocity of air at the inlet is 4 kmph. Is there any method to reduce this velocity.
praroopjain is offline   Reply With Quote
Old   January 11, 2015, 06:31
MB72 is on a distinguished road
If you are allowed to change the nozzle design geometry, and the solution you are obtaining sounds good (=converge) (I don't have enough data to judge), the easiest way is to enlarge the nozzle outlet.
Another way is to have a powerful energy dissipation inside the nozzle (something like a very dissipating porous media = very "dense" filter. Porous media is very quick to model in almost all CFD commercial code).
However let me tell you, that if the intake velocity is just 4 km/h and the outlet is 1000 km/h (if I undrstood well) there is for sure some convergence problem, if you are working at ambient pressure (may I know the inlet/outlet absolute pressure?)
Check the mass continuity at inlet/outlet and you will "debug" your solution. The inlet mass flow rate (in kg/h) should be the same as the outlet mass.
Regards
praroopjain likes this.
MB72 is offline   Reply With Quote
Old   January 11, 2015, 12:59
Praroop Jain
Absolute Pressure at both the ends (inlet/outlet) is same as that of atmospheric pressure (i.e. 1 atm).
Old   January 11, 2015, 15:44
OK. I think we have a problem.
If we want to have a movement of the fluid (air) from inlet to outlet we need to establish a pressure difference between inlet and outlet, or the fluid doesn't move.
My suggestion is to use a much more robust strategy to solve the problem:
1)INLET: impose just mass flow rate (starting with a very low mass flow rate)
2)OUTLET: impose the pressure (in this case 1 atm)
3)Check carefully the results and determine the average inlet pressure.
4)Check if the outlet mass flow rate is the same (within 1% of the value) of those imposed at inlet.
5)Eventually you will use this pressure value in a final (much refined) simulation.
Regards
Old   January 11, 2015, 23:04
Praroop Jain
Ok, I m gonna try it.
Thanks
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow Jing Main CFD Forum 8 October 5, 2018 17:02
UDF for transient pressure inlet, mass flow check at nozzle exit and volumetric heat kokoory FLUENT 0 August 17, 2011 02:07
Compressible de Laval Nozzle Flow rw511 CFX 3 May 22, 2011 19:48
Flow simulation in a Pelton turbine nozzle fivos FLUENT 0 April 19, 2011 11:46
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 07:59
