iso-surface
Old   January 18, 2015, 15:51
Default iso-surface
alliche redha
cheredha is on a distinguished road
hi,
how to creat iso-surface in the cylinder (2D), I know for a plate simply break on the x-axis (hence vertical line "column").
I need to calculate h (heat coeff)
cheredha is offline   Reply With Quote
Old   January 19, 2015, 08:41
Cees Haringa
CeesH is on a distinguished road
I'm not very sure of what you want. An Iso-surface of what? constant coordinate? Constant temperature?
CeesH is offline   Reply With Quote
Old   January 19, 2015, 10:23
alliche redha
hi,
i want the constant coordinate, but for different "théta",
[ICEM] Surface mesh not sticking to surface holtwong ANSYS Meshing & Geometry 2 April 20, 2023 08:28
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
Recover surface from surface mesh in IcemCFD Jerry Tanner CFX 0 August 20, 2008 12:48
Vorticity iso surface around propeller in CCM+ Dan Siemens 2 January 23, 2007 14:17
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin Kaushik FLUENT 1 May 8, 2000 06:47
