Turbulent Intensity boundary condition
Old   February 4, 2015, 09:26
Default Turbulent Intensity boundary condition
egge24 is on a distinguished road
Hi everybody,
Does anyone know how I can precribe a turbulent intensity boundary condition at an inlet velocity boundary? I´m trying to model a 3d rectangular channel with a constant flow and constant turbulent intensity of 10% at the inlet.
Thank you.
Regards,
egge24
egge24 is offline   Reply With Quote
Old   February 4, 2015, 10:53
Anonymous
marauder is on a distinguished road
Select a turbulence model then go to inlet boundary condition, at the bottom in first tab select Intensity & Hydraulic diameter and the give the values.
Intensity & viscosity ratio can also be selected if you can calculate them.
marauder is offline   Reply With Quote
Old   February 4, 2015, 11:23
Marauder,
Thank you for your fast response.
I did that, but once I run my model in steady state the surface contour of the inlet shows values of Turbulence below 10%, see figure. I want the lowest value of turbulence intensity at the inlet to be 10%.
Any ideas?
Thank you
Problem with divergence TDK FLUENT 13 December 14, 2018 06:00
turbulent boundary condition for inlet half sphere shape asal FLUENT 0 January 7, 2014 11:09
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
Turbulent intensity for pressure Outlet Boundary condition Mohsin FLUENT 1 April 30, 2010 10:36
setting value of turbulent intensity and turbulent viscosity ratio in wind tunnel nuimlabib Main CFD Forum 0 August 4, 2009 00:05
