nozzle in fluent
Old   February 5, 2015, 08:30
Default nozzle in fluent
FC
frafole is on a distinguished road
I'm simulating a convegent divergent nozzle in fluent with air. I've noticed that the AreaAvarage pressure in inlet changes when I change the dimensions of the nozzle, even if I set as BC ambient pressure inlet; why does that happen? Otherwise I'm searching for the minor pressure drops from inlet to outlet, and I don't undestand why pressure drops seems that have more than one minimum value if I modify the length of the nozzle without changing the angles, but in theory pressure drops should be linear. Does anyone know what I'm probably missing?
thank you very much.
frafole is offline   Reply With Quote
Old   February 8, 2015, 05:18
ssixr's Avatar
sudhir
ssixr is on a distinguished road
Originally Posted by frafole View Post
Hi frafole,
Area Average concept is based on surface area...please check fluent documentation.
ssixr is offline   Reply With Quote
Old   February 8, 2015, 05:34
FC
Originally Posted by ssixr View Post
Hi frafole,
Yes, it makes a surface integral of the pressure, so the results doesen't depend on the size of the surface but its a mean pressure.
Old   February 8, 2015, 05:41
ssixr's Avatar
sudhir
The area-weighted average of a quantity is computed by dividing the summation of the product of the selected field variable and facet area by the total area of the surface..
check this link http://aerojet.engr.ucdavis.edu/flue...g/node1199.htm
sudhir
Old   February 8, 2015, 06:03
FC
sudhir
Ok, so in your opinion how can I do to calcolate the mean absolute pressure on a surface that is independent from its size?
Thank you for your help.
Old   February 8, 2015, 06:15
ssixr's Avatar
sudhir
Node or mass weighted average would be a better choice in my opinion. Hope it helps..
Old   February 8, 2015, 06:22
FC
I just tired with both methods but there is a difference of 7Pa from the results of area avarege method so my problem persists...
Old   February 14, 2015, 00:28
ssixr's Avatar
sudhir
are you changing geometry of inlet?
sudhir
looking for a smart interface matlab fluent chary FLUENT 24 June 18, 2021 09:07
Solid Rocket Nozzle - Fluent 5 Tutorial Guide Ijaz FLUENT 4 April 2, 2015 20:46
What the differences flow equation of Fluent 6.3 and Fluent 12.1 opehterinar81 FLUENT 0 August 19, 2011 11:55
analyze a cd nozzle with fluent which designed by MOC mehrzad Main CFD Forum 0 July 6, 2011 04:33
Pressdrop across in nozzle: Fluent Paul Main CFD Forum 8 January 15, 2006 02:24
