combustion with injection of particles: Gravity ON = calculation of DPM is very slow
Old   February 3, 2015, 09:02
Default combustion with injection of particles: Gravity ON = calculation of DPM is very slow
Nikolaos Babilas
NiBa is on a distinguished road
Hello everyone i have a combustion with injection of particles. i noticed that when i activate gravity the calculation of DPM is very slow and all the particles are incomplete. does anyone know if it is necessary to activate gravity for my problem?
thank you
NiBa is offline   Reply With Quote
Old   February 3, 2015, 14:27
edoan's Avatar
Ethan Doan
edoan is on a distinguished road
I think gravity will be important if the density difference between the two phases (rhop-rho) is large enough to make the second term non negligible to the first term.
dup/dt = Fd(u-up) + (g(rhop-rho)/rhop) +F
edoan is offline   Reply With Quote
Old   February 3, 2015, 20:33
John Yu
fishball is on a distinguished road
thank you
You could try to change the Step length factor to speed up the calculation of DPM or Particle time step size for unsteady particle tracking.
fishball is offline   Reply With Quote
Old   February 4, 2015, 05:36
Nikolaos Babilas
do you believe that i should increase or reduce the step length factor?
thank you
Old   February 9, 2015, 01:26
John Yu
thank you
I guess you should try to see between the calculation speed and accuracy, but how much particle, max step and calculation time you are using now?
Multicomponent DPM injection Mohsin FLUENT 27 August 21, 2017 09:50
trying to simulate two-phase jet flow with particles in surface injection ajkratos FLUENT 5 March 3, 2015 21:33
Conditional Release of DPM Particles in Fluent - UDF nvschandra Fluent UDF and Scheme Programming 0 December 16, 2013 20:32
Dense DPM Injection Help (basic sedimentation) sgelman FLUENT 0 July 21, 2010 14:19
Coal particles in combustion chamber Luis Filipe Fabiani CFX 2 March 10, 2009 15:37
