problem with periodic BC
Old   February 9, 2015, 01:11
Default problem with periodic BC
joseph
josephmp is on a distinguished road
hi friends, when i applied periodic BC at the inlet and outlet of a 2D unitcell of a microchannel with specified mass flow rate, i got a seemingly unphysical pressure variation along the centre line with negative pressure towards the downstream end. But when i avoid the periodic BC and arrange unitcells in series with velocity inlet and pressure outlet BCs i get finite pressure drop. Why the periodic BC is not working? why the negative pressure? can you help me to solve this problem...?
josephmp is offline   Reply With Quote
Old   February 9, 2015, 06:18
amin.z's Avatar
Amin
amin.z is on a distinguished road
please attach some pic from your model...
amin.z is offline   Reply With Quote
Old   February 10, 2015, 00:15
joseph
i m trying to model two type of 2D microchannels (the periodic module have dimensions around 0.2mm*0.6mm)
1.channel with noslip boundaries
2.channel with alternate slip and noslip boundaries at bottom surface
for both cases i applied periodic BC at inlet and outlet with a specified mass flow rate such that Re nearly equals 0.1
1.the pics numbered 5 gives the pressure variation for for 1st case with
periodic zone=inlet
shadow zone=outlet
pic 6 gives pressure variation for 1st noslip case with
periodic zone=outlet
shadow zone=inlet
2.the pics numbered 2-4 gives 2nd case with alternate slip and noslp boundaries
for the first case why am i getting negative pressures? is there any method to eliminate end effects?
for the 2nd case why the pressure varies like a zigzag manner? why i am not getting a pressure drop?
2.boundaries.pdf
Old   February 11, 2015, 01:12
joseph
if my problem description is having less clarity plz tell me ...i can clear it....
Periodic and projection problem crostolo Pointwise & Gridgen 9 March 7, 2017 02:48
Problem in generating a periodic boundary Adhillon111 Mesh Generation & Pre-Processing 0 October 28, 2014 02:17
Problem with Axis of rotation in Periodic BC mohammad STAR-CCM+ 2 September 5, 2014 05:33
3Dimensional periodic boundary condition bench mark problem for incompressible HaKu Main CFD Forum 0 September 7, 2011 13:48
periodic flow problem Alok Gupta FLUENT 1 November 19, 2003 07:05
