October 3, 2016, 09:06 |
Multiphase species transport
Marcelo Costa
Rep Power: 11 |
I'm having a problem with Fluent regarding mass transfer between phases of species. Just for testing purposes, we've created a simple geometry consisting in a 2D rectangle (5 mm wide and 10 mm height). We divided the rectangle in half, so that each of the half's would contain one phase. So in total we have 2 phases. The domain is closed, there is not inlets and no outlets, it's an isolated system where we want a specie to go from phase-2 to phase-1. In top part of the rectangle, we have phase 2: - 50% oil (same properties of water) and 50% tracer (same properties of water) In the bottom parte, we have phase 1: - 100% water and 0% tracer (same properties of water) Initially we assumed an equilibrium ratio of 1, so I would expect that 50% of the tracer from phase 2 would be transferred to phase 1. I'm currently using an Eulerian model (Multi-VOF), and I am assuming a constant mass transfer coefficient of 1000 (it's not realistic, I know). The transfer mechanism is from phase-2 to phase-1 of tracer. The problem is that everytime I try to simulate this, nothing appears to happen. Nothing other than some residual amount of tracer in phase-1 (like 1e-10 or something, which I don't really attribute to the physical model, but maybe numerical problem). Has anyone tried something similar? This is just a preliminary test, because what I really want to simulate is a pure diffusional mas transfer in the interphase, which I believe, I need an UDF to do so. Thanks PS: posted again on Multiphase subforum. Please delet this |
December 3, 2016, 12:27 |
Adriana
Rep Power: 13 |
I'm not too familiar with the VOF model, but I would think that maybe the challenge may be how you are defining the tracer, and how this is related to the volume (Vfraction-phase2 = 0.5 of oil) occupied in the secondary phase.
Species transport in multiphase flow | Dinar | FLUENT | 7 | December 3, 2016 12:46 |
Should I use Multiphase mode or Species transport?? | qya12 | FLUENT | 1 | March 30, 2012 05:40 |
Species Transport with Multiphase flow in FBR | venkat | FLUENT | 1 | July 23, 2008 23:53 |
Species transport in multiphase... | masood yooceframandi | FLUENT | 0 | February 11, 2006 01:10 |
Species Transport with multiphase flow | Gopal Kasat | FLUENT | 3 | July 12, 2005 18:59 |
