October 24, 2016, 07:01 |
Strange results on Fluent, mesh related?
Rep Power: 11 |
Hi all,
I've been meshing some blocks with 6 solids in the domain (3 cubes, 1 cuboid, floor, ceiling) and been running some CFD and had noticed after computation, the contour results are not smooth transition been sections of the mesh as attached which I also believe is related to the flat iso-surfaces along each refinement region. The y+ for each region is around 5, turbulence model is k-omega sst so the wall distance is very small. The mesh was generated using Pointwise. Is there anyway I could resolve this, whilst keeping the mesh y-plus consistent around the solid boundaries? |
fluent 16.2, pointwise cgns msh |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
Interesting problem: Parallel Processor VOF Fluent + Dynamic Mesh + System Coupling | spaceprop | FLUENT | 5 | September 2, 2014 09:43 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
FLUENT Not Recognizing That Mesh Has Been Updated | tantin | FLUENT | 0 | January 7, 2013 19:01 |
