3D multiphase micro model: mixing effect of air and water at the T junction
Old   November 25, 2009, 05:49
Default 3D multiphase micro model: mixing effect of air and water at the T junction
Ehsan Fareed
ehsanfareed is on a distinguished road
Hi All,
I have a T shape (3D) micro channel, from the left air enters and from below water enters (both are velocity inlets), the flow is laminar, time unsteady, VOF model. I want to see the mixing effect of air and water at the T junction. It is supposed to be a bubble formation at the junction and the bubble is then carried away with the air flow to the outlet (pressure outlet).
But what I get is that water level starts to rise in the channel and there is no mixing effect or bubble formation, I get a clear phase boundary between air and water, you can see the picture.
http://yfrog.com/ek61388547j
I dont know what is the problem, Also I want to use PTFE as a wall material to see its effect on the water as it is a hydrophobic material, but I am unable to define a User Define Material Database for PTFE. Also I want to know that which property of PTFE should be given which defines its hydrophobic character.
Please help me in the above 2 problems I am having regarding the mixing effect and the PTFE material, I shall be thankful to you.
Regards,
Ehsan Fareed
ehsanfareed is offline   Reply With Quote
Old   November 30, 2009, 13:56
Ehsan Fareed
C'mon anyone....................????
Old   March 22, 2015, 22:29
Ash
ashish.nitame is on a distinguished road
hello,
did you reach to any solution because even I am stuck with the same problem of "no buuble formation" (stratified flow).
ashish.nitame is offline   Reply With Quote
Multiphase model, water disperses in air bugra Main CFD Forum 1 January 30, 2010 10:57
multiphase model, water in air? bugra Main CFD Forum 10 January 2, 2010 13:09
Help needed in 3D multiphase micro model ehsanfareed FLOW-3D 1 November 29, 2009 19:07
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 07:59
air and water vapour mixture - multiphase model Saba FLUENT 0 February 10, 2009 12:05
