April 3, 2015, 13:52 |
Vortex Breakdown
Thomas Milin
Rep Power: 11 |
Respected Users,
I am doing a simulation of the vortex breakdown phenomena in an open cylinder(top) with rotating bottom wall. I am using water as the fluid and the bottom is rotated at Re=2600 as per the journal. The top is open to the atmosphere. At Re=2600 I am getting the exact replica of the vector plot but as the Reynolds number is increased I am not able to obtain the vortex breakdown phenomena. Breakdown was obtained in the journal at Re=3000. Following are the input parameters i am giving in fluent. Solver- Pressure based ,steady, relative Models- Laminar(all others off) Materials- water (from database) Cell zone condition- interior volume is made fluid and material is made water.The rotation axis origin is given as (0,0,0) and rotation axis direction as (0,0,1)(all other boxes are left unchecked) Boundary conditions- top is made pressure inlet bottom is made rotating by imparting angular velocity(by selecting moving,rotational,absolute) of .104667rad/s. radius is 15.23cm and height is 63.19cm side is made a no slip wall Reference values- compute from bottom is given and reference values are left as such, reference zone is selected as interior volume Solution methods- simple, least square cell based, second order, second order upwind Solution controls- under relaxation factors are retained as such(i.e pressure .3, body forces 1, density 1, momentum .7) Standard absolute initialization is given These are the various input parameters I am giving yet i am not able to obtain the breakdown phenomena. Any comments will be really valuable. Thanking you for your patience and help. P.S] I am also enclosing the velocity contour plot of my simulation at Re=2600 |
April 6, 2015, 00:36 |
Thomas Milin
Rep Power: 11 |
Thank you very much for your suggestions . Let me make a simulation with your suggestions and ill post the result.
Yes i think so. Consider the case of shock waves generated when the valve of a penstock pipe is closed. |
April 16, 2015, 04:55 |
Thomas Milin
Rep Power: 11 |
The transient mode you specified is also not yielding any vortex breakdown phenomenon. It is also giving the exact same result as i used to get with previous cases. Do you have any other alternatives for the problem.
Thank You |
Vortex breakdown | thomasmilin321 | ANSYS | 1 | October 13, 2014 12:23 |
Presenation of vortex strength and velocity concept? | fruitkiwi | Main CFD Forum | 0 | September 26, 2012 22:08 |
Vortex breakdown | thecfduser | Main CFD Forum | 0 | July 10, 2010 02:47 |
vortex breakdown | daniel | Main CFD Forum | 13 | February 19, 2004 10:25 |
Vortex Breakdown / Diffuser Performance | Olu | Main CFD Forum | 1 | November 11, 1998 12:49 |
