April 17, 2015, 12:37 |
Ansys Fluent analysis of heat exchanger
Rep Power: 11 |
Hello everyone,
I am a Master student currently working on my thesis which includes the design and analysis of a heat exchanger. My Promotor/Professor would like for me to do an analysis on the heat exchanger using the Ansys Fluent module... I am however having some difficulty getting the correct settings and I was hoping I could get some help here (because I am running out of time).. The heat exchanger design that was chosen is a simple concentric tube (double pipe) heat exchanger in counterflow configuration, I think I have the intakes and outlets labeled correctly, but I'm having some trouble correctly defining the heat transfer surfaces. As well as setting the correct boundary conditions. The fluids are Hydrogen gas through the straight pipe and water in counterflow through the annulus. I am using Ansys workbench 15.0 HX CAD file: https://drive.google.com/file/d/0B15...ew?usp=sharing Ansys Project file: https://drive.google.com/file/d/0B15...ew?usp=sharing Thanks in advance for any help you can give me, MS |
April 18, 2015, 03:28 |
Amin
Rep Power: 14 |
what is your problem exactly? explain more please...
April 20, 2015, 08:40 |
Rep Power: 11 |
My problem is simply that I've never used the software before and I am running out of time for my thesis. So I don't exactly have time to figure this all out myself based on trial and error.
I don't know if what I've already done in the project I've uploaded is correct or the proper way to go from there in order to be able to start analyzing the heat exchanger. I have the user guide and tutorials, but so far I haven't been able to really get what I need from that. So maybe if someone could point me in the direction of a step-by-step for heat exchangers or something... I'm not asking to have the work done for me, just for someone to check the work that's already been done and explain how to go from there... - How do I select the heat transfer surfaces? Does it matter if I select the in or outside of the inner pipe, do I select both? - How do I set the boundry layers for this and which ones do I need? - Any more explanation to get this working is always welcome |
heat exchanger analysis | durgesh pal | Main CFD Forum | 2 | January 29, 2015 05:03 |
2D model of a tube in tube heat exchanger in fluent | raveesh | FLUENT | 1 | July 9, 2014 08:11 |
heat exchanger drawing in Ansys Geometry | flyEmirates | ANSYS Meshing & Geometry | 1 | June 7, 2011 08:01 |
Transient FSI heat transfer using FLUENT and ANSYS | kevpw | FLUENT | 0 | March 26, 2010 16:04 |
How does FLUENT fair in absolute heat transfer analysis | Steve Aboagye | Main CFD Forum | 1 | August 31, 1998 12:12 |
