Heat transfer under oscillating flow through porous media
Old   February 5, 2015, 08:05
Default Heat transfer under oscillating flow through porous media
highhopes is on a distinguished road
Hello everyone,
I am having some issues with my 2D axisymmetric model. I am trying to get a constant temperature average on a heated pipe interior wall exposed to oscillating flow.
Imagine a long pipe with porous region covering 1/7 of the pipe in the middle. The wall of the porous part is heated by introducing constant heat flux. The fluid, water in this case, is oscillated with a low frequency. The domain is also cooled down through the remaining surface.
However, the cooling cannot set a balance and the wall temperature keeps increasing even though the axial temperature gradient right outside the foam is extremely high.
I have been using RNG k-epsilon with enhanced wall treatment (y+ around 0.8) and PISO as the pressure-velocity coupling.
I think that the mixing is not effective enough. Is there an option you would recommend mixing-related? Or is there any detail that needs to be known about solving convection-diffusion problems with Fluent.
I would appreciate any kind of help.
Thank you
highhopes is offline   Reply With Quote
Old   February 5, 2015, 11:37
Vishnu
vishnuktm is on a distinguished road
I am doing a similar work on thermoacoustic refrigerator. How do you create a low freq oscillation. Can you please explain.
vishnuktm is offline   Reply With Quote
Old   February 5, 2015, 17:03
I introduced sinusoidal functions with the desired frequencies as user defined velocities at both ends. They had different signs, but same magnitudes.
Old   February 10, 2015, 03:37
Could anyone point me to a viable finite volume study on oscillatory heat transfer? Because I haven't found a solution so far.
And, is there a way to save the hydrodynamic data at each time step in order to avoid calculation every oscillation cycle so that fluent will only solve the energy equations?
Old   April 22, 2015, 00:49
sache is on a distinguished road
Hey,
have you got the answer,
sache is offline   Reply With Quote
UDF for heat transfer coefficient in porous media anon_m FLUENT 0 July 24, 2014 18:37
Conductive heat transfer in porous media Nevel CFX 2 August 24, 2010 18:41
Two phase flow in porous media Madhavi Krishnan FLUENT 3 June 6, 2005 05:52
porous media: Fluent or Star-CD? Igor Main CFD Forum 0 December 5, 2002 15:16
heat transfer in porous media Jörg Brozio FLUENT 1 March 28, 2000 23:17
