Divergence when TI of inlet is low
Old   April 27, 2015, 17:33
Default Divergence when TI of inlet is low
buidu
buidu is on a distinguished road
Dear all,
I am running a simulation to study convective heat loss from cylinder. When I set the the boundry of inlet with a turbulent intensity(TI) of 5%, it can converge very well. However, when I set the Ti as 0.1%, the calculation divergeced at around 50 steps. If I want to run a simulation with low TI, e.g. 0.1%, does anyone know how should I set the boundry condition? The calculation domain is in the attachment.
Thank you very much.
Regards,
Hao
buidu is offline   Reply With Quote
Old   April 27, 2015, 21:03
Lucky
Are you changing only the TI at the inlet? What about the initialization? The initialization is very important. You need to adjust the value of k, epsilon/omega to better guesses.
Old   April 28, 2015, 03:02
buidu
I just changed the TI. I tried to change other parameters, but I cannot find any reference on how to calculate them. The tutorial that Ansys provides only gives the assumption when the flow is fully developed. Could you give my some hints on it? How should I calculate the parameters? Thank you very much.
Hao
Floating Point Exception Error nyox FLUENT 11 November 30, 2018 12:31
Divergence problem Smaras FLUENT 13 February 21, 2013 05:03
3d vof Smaras FLUENT 2 February 19, 2013 06:58
Low flow rate in channel results in divergence Purushothama Siemens 0 March 16, 2011 22:23
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
