Journal File Error - Occurs ONLY if I change the name of the mesh |
July 24, 2023, 09:15 |
Rep Power: 5 |
Hello everyone!
how are you all doing? I've set up a journal file in Fluent by 'writing' my actions and is able to execute successfully with zero problems. However, the moment I change the name of the mesh to be read within the journal (I have said mesh in the right folder, and is exactly similar to the mesh used when creating the journal file, just with different number of elements), the journal crashes and fluent throws an error. Code:
Error: cx-name-to-id: cannot find widget: Error Object: "Solid*Frame2*Table3*Frame1" There is no access issue, no location mismatch issue, no different kind of mesh issue, nothing. I have no idea why Fluent journal execution crashes solely when I change the name of the mesh to be read in the journal. I am at the end of my wits, please help asap! |
error, fluent, journal, mesh |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 03:30 |
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 09:07 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 03:23 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
