How to obtain radially a static pressure contour |
May 2, 2015, 08:07 |
Aja
Rep Power: 14 |
I designed and analyzed a turbine by using Gamibit and fluent softwares. Turbine have 6 blades.((360/6)=60 deg=angle between blades) Due to the circumferential symmetry, only one sixth of the annulus has been computed, imposing periodic boundary conditions in the tangential direction. The computational domain has been restricted in the axial direction to six chord lengths upstream and ten chord lengths downstream of the blade. Now, I want to obtain radially a static pressure contour at Middle of turbine blade by using fluent. How do this action? Then, I want to import this contour in tecplot. Thanks. Amir Best |
May 2, 2015, 10:47 |
Aja
Rep Power: 14 |
Can no one guide?
Pressure Inlet VS velocity Inlet difference | Mohsin | FLUENT | 9 | January 4, 2021 10:34 |
Pressure Outlet Guage pressure | Mohsin | FLUENT | 36 | April 29, 2016 17:16 |
CFX4.2 Pressure contour kink | Stuart McCallum | CFX | 3 | July 7, 2000 14:09 |
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) | HB &DS | CFX | 0 | January 9, 2000 13:19 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
