Grid adaption for CHT
Old   February 16, 2024, 02:57
Default Grid adaption for CHT
Pierre LECHEVALIER
PierreLCV is on a distinguished road
Dear CFD community,
I am currently working on CHT simulation which is quite classical (water circulating in a heated solid copper). I work roughly always on the same design but sometime i have to change slightly the solid part and the thermalhydraulic conditions (mainly the velocity).
Of course, it implies that i have to perform a new mesh independency study to validate my results and this part is very time consuming. That is why I thought about mesh adaption possibilities and how could I use this to obtain the best results from my simulation (and thus obtain mesh independent results with a few meshs). However, I have tried to use this tool based on residuals (momentum and energy) but the refinement of the cells which presents the highest residuals seems to not change a lot the results... Damn !!!!
That is why I need some help about that. How could I use mesh adaption in Fluent to obtain highest convergence ? Should I increase the numbers of refined cells ? Maybe is it a better idea to adapt the mesh based on cells gradient ? But in this case which order of magnitude should I consider for the refinement threshld ?
As you can see, I am looking for some guidelines to use mesh adaption tools to improve my simulations convergence.
Thank you for your help,
Best regards,
Pierre
PierreLCV is offline   Reply With Quote
IBM grid recognition in foam-extend 4.1 Guanzhu OpenFOAM 0 January 25, 2021 21:23
Grid adaption mhdmk FLUENT 0 September 20, 2013 01:30
Grid adaption problem William FLUENT 0 May 25, 2006 07:14
Grid Adaption problems Jie FLUENT 1 February 26, 2002 11:03
How much is the refine threshold for grid adaption Jie FLUENT 0 February 21, 2002 00:43
