Mesh motion in ANSYS FLUENT
Old   May 11, 2015, 10:05
Default Mesh motion in ANSYS FLUENT
rsdsaurav is on a distinguished road
Send a message via Skype™ to rsdsaurav
In ANSYS FLUENT using Moving Frame of Reference renders an unsteady process steady. So does using mesh motion also renders the problem from unsteady to steady or does it still remains unsteady?
rsdsaurav is offline   Reply With Quote
Old   May 14, 2015, 14:29
Emre G
emreg is on a distinguished road
Moving mesh can be attained in "Sliding Mesh" mode. MRF cannot be thought as moving motion directly.
emreg is offline   Reply With Quote
Old   May 14, 2015, 22:16
Default Rotating Motion in Ansys Fluent
Then Sir what is the right method of of considering the rotating motion? The geometry has one rotor rotating which is housed in a static stator.
Old   May 15, 2015, 02:21
ghost82's Avatar
Rick
ghost82 will become famous soon enough
MRF or SRF should be enough for this problem.
Daniele
Google is your friend and the same for the search button!
ghost82 is offline   Reply With Quote
difference between frame motion and mesh motion in fluent s.jaiswal FLUENT 5 April 29, 2021 21:59
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
FLUENT Not Recognizing That Mesh Has Been Updated tantin FLUENT 0 January 7, 2013 19:01
Automatic Mesh Motion solver michele OpenFOAM Running, Solving & CFD 10 September 26, 2005 08:21
Mesh data exchange from ansys to fluent Yong-Ju Hong FLUENT 0 January 28, 2001 21:42
