temperature losing region
Like Tree1Likes
  • 1 Post By Steffen595
Old   July 23, 2015, 20:02
Default temperature losing region
hwet is on a distinguished road
Hi
Can I make a region inside my volume where the gas will rapidly lose temperature depending on the regions temperature as it passes through it.
This is not the same as making the walls a different temperature, also if i patch a region with a temperature that will only be an initialization. I want this region to constantly have a low temperature.
hwet is offline   Reply With Quote
Old   July 24, 2015, 01:15
Steffen595 is on a distinguished road
cant you just put in a subdomain and make it a heat source. Then chose a negative value? I can try and pull my heat source model out later on today.
hwet likes this.
Steffen595 is offline   Reply With Quote
Old   July 24, 2015, 19:00
I tried, works. Temperature is sinking. I had 2 models for a buoyancy simulation. One with heated walls and one with a 2nd domain and a heat sourc. If I make the heat flux a negative value, the temperature drops.
Old   July 24, 2015, 22:59
how can i relate the heat flux to the temperature, i cant just put in a random negative value can i.
For me the gas passes through a zone with water at 24 C, since I am not doing this as a multiphase simulation and just considering the gas, I want it to lose its temperature as it would to water in that zone if water was there and this was a miultiphase simulatiion. Hope I make sense
Old   July 24, 2015, 23:38
you have to put in some heat flux in kW per m^2 on that boundary wall where the gas touches the water. Pipe surface or whatever you are using.
http://www.cfd-online.com/Forums/cfx...et-outlet.html
thats the thread I startes on a simular topic. You can make a fluid domain and have a wall with heat flux per m^2. Or make 2 domains, one is a heat source with heat flux per m^3.
Old   July 25, 2015, 00:33
OK thanks, I will try this
Can I use fvOptions to couple a solid region and a fluid region? titanchao OpenFOAM Running, Solving & CFD 4 January 14, 2022 07:55
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 07:15
Temperature condition inside an entire region Twinsen_cfd STAR-CCM+ 2 November 20, 2014 03:36
High temperature methane+air Peter FLUENT 5 January 26, 2009 18:04
An issue with temperature change in unsteady prob Ashok kumar FLUENT 1 January 13, 2009 04:34
